Removing fork sliders...
  • Bunyip
    Bunyip
     Gday guys....going to powdercoat my sliders and add some gators to forks.....anyone here removed sliders? Off work for a bit and bike is still waiting for some parts so cant ride it anyway.....
    any advice or thoughts would be appreciated...
  • Bunyip
    Bunyip
    Genius, thanks mate, will track it down.
    if you don't know how too or do not have the right seal installer etc , if the seals are not leaking  just pull fork's out off bike complete a mask-up the tubes  & paint strip  the lowers  & polish alloy ,  or 2 pack black paint , if you can not do the rebuild with new seals & bushes  find someone  to  help you  but do not scratch the hard chrome fork tubes  most important
  • Bunyip
    Bunyip
    Thanks Daddio.
