Online: beaglebasher
what jets do you recomend?
  • mylesb86
    mylesb86
    I have just fitted a screaming eagle heavy breather and freedom performance sharp curve radius pipes and i was wondering what jets any one would use/recomend for my stock cv carb?
  • Anmac
    Anmac
    Sorry, but I can't help myself.
    Screaming Jets?
    What jets are you running now ?
  • mylesb86
    mylesb86
    It's 1993 heritage softail engine is stock with a SE ignition and the breather and pipes, the jets are the factory ones. Ive spent sometime adjusting the mixture screw but Im still getting the occasional cough through the carbie when I back right off and then give it a big squirt on the throttle and the pipes "pop" when going down hill or when I back off it on high rpm, this is my first Harley and a bit of a learning curve for me so any help would be appreciated.
    How many turns out on the mixture screw works best ? does it need choke when cold ?
    This will tell you where your at with the pilot.
    Impossible to properly jet your bike for you by remote, but go up 5 points max' on the main would be a start.
    There is some good reading on the Net' for Carb' jetting tips.
  • mylesb86
    mylesb86
    Ive played around with it a bit more today and adjusted the mixture screw out 4.5 turns and the cough in the carb is gone aswell as the exhaust popping it seems a tiny bit sluggish on take off so next time i head out for i ride ill screw in the mixture screw in little bit more and see how i go. cheers for your help
  • mylesb86
    mylesb86
    the top end has a cough when your up in the revs and back off and then give it some again
  • mylesb86
    mylesb86
    yeah holding it flat and backing off
    the cough is from the carbie
  • mylesb86
    mylesb86
    yeah thats exactly whats happening
    ill check the the exhaust flange nuts next time im down the shed and see if they need a tighten up
  • mylesb86
    mylesb86
    no worries mate thanks looks like ill be getting me a rejetting kit
  • mylesb86
    mylesb86
    I put a 48 pilot jet in today and the bike goes a shit load better seems just a little bit lean right up in the top of the rev range though I havnt swapped the main jet yet though would that be the cause of it?
  • mylesb86
    mylesb86
    I did the test and it all checks out good so I'll stop messing with it!
    Thank you for your help and advice it's been very much appreciated and I've learnt a lot about tuning carbs
    Cheers myles
