Why the Evo is a better engine than your Twinklie
    BC, the EVO was a good motor, But far from perfect.
    the Twin Cam is also a good motor & yet again far from perfect.
    in the end i don't think anything is perfect mate.
    i'll tell you what i have seen. i've seen a heap of EVO's crack the cases between the rear lifter block & the barrel.  I had never seen one braek a crank pin till 4 years ago then saw 4 of them with broken crank pin's in a period on just over a year.
    the good thing with the EVO is you can rebuild the bottom end, this would allow high quality rods if you had the coin.
    i had my 01 Twin Cam slip the pin in the crank after around 80,000k very hard k's got a like new stock replacement set of flywheels & had the crank pin welded to stop slipping, all i can hope for is that my stock rods will stand up but with the stock TC 88 stroke being shorter there is less piston speed at a given rev, so i hope they last. when she was still a baby the stock chain tentioners fell apart, was just lucky to get it while all parts were still in cam chest. so got my m8 in USA to pick up some S&S Gear drive cams. i'm pretty happy with how she has stood up. if it breaks so be it.
    this ( what i wrote about my personal ride ) is just a Dyna twin cam. if your compairing softails i would say the Twin Cam Softail heaps better, one of my riding & racing m8's road the Ring right out of a EVO softail, it was only an 80 incher, but it flew, trouble was high rev vibration everything would crack or fall off, he used to hold it together with plastic tyes.
  • jacko88
    jacko88
    a lot of stuff in that article I knew as I have rebuilt Evos from the ground up several times and they are bullet proof except for that bad batch of cases in the 90's Krash is referring to. The twin cam can be bullet proof to with welded and trued cranks, timkin bearings and gear drive cams and chuck the efi shit in the bin where it belongs. The twin cams are a far better ride if you are doing lottsa miles and long days.......no question and that is an opinion gained from riding shovels, evo,s and twin cams great article cooky
  • Sparra
    Sparra
    After reading that I am seriously thinking about keeping my Evo...It does everything I want it to do so maybe keeping up with the jones's isn't neccesary...
    Cheers...Sparra
  • robcig
    robcig
    Great read, thanks for posting!! My twin cam is getting on a bit, apart from cams, bearings and tensioners, she has been reliable. I like the fact I have a carbie, and don't have to stuff around with ECUs and maps and downloads....as he says, complicated!!
  • HogBag
    HogBag
    This has been going on for 60 years in the Harley world with flat heads, knuckle heads, pan heads, genny shovels, AMF shovels, block heads and now the fat heads (twin cams). The next engine will probably be called water heads and all us twin cam owners will be bagging them in 10 years. Its easy to make 100/100 with a TC motor with good heads, cams, pipe and tune. Don't get me wrong I would love a early shovel roadglide with a S&S 113 evo motor jammed in it for a bar hopper but I will keep the rubber mounted wobble glide for my long range tourer.
  • stumbly1
    stumbly1
    I won't bite 1 way or the other, but the last bit of the article sums it up -
    "I mean, how often is it that you ask a man why his five year old bike only has 10,000 miles on it and he replies that he’s to busy working to ride"
    "For in the end the only real question is: Did you enjoy your life more often than you didn’t? If the answer is yes then you died a very rich man."
  • Evo
    Evo
    I have ridden my old evo for years and will continue to do so. Simple reason is I know what is in that motor and I trust her to get me home.
  • blueystar
    blueystar
    now i know why the roadsweeper is still in the shed and the finger burner got traded
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    i got my first harley at 16yr old an 49 frame with duo glide front end an a 56 pan in it had her for 10yrs rode it to broome from sydney in 79 / 80 an got a shovel ended up havin heaps shovels all the way up to 95 then got an evo had springers fxr an few other evos never had a twin cam but i reckon that they are a good motor but harley forgot to do it correct at the factory if they had of put either rebuildable flywheels like evos or even welded ones a billet oil pump gear drives and had a bit more done to heads they wouldve been gettin rave reveiws instead of pissed off ppl all over the world .i love all harleys but the evo is by far the best motor if ya want to own a bike that will get ya there n back again an not cost ya afortune to fix if something went wrong also the fact that they were carb modles mainly (were few injected ones ) which meant bein able to carry few bits so side of road tune could get ya goin again if ya break down now most need a tow (call me if ya up this way lol) an that will piss anyone off .if ya want a bike oops my bad if ya want a motor with the real old skool look ya cant beat the shovels or pans s&s make good ones but pull em down an regap it before ya ride seen em missing sopacers an few gaps were way wrong
    all in all harleys have been here over the 100yrs so i still reckon they be here another hundred unless the gumbyment says bikes are to dangerous or they make em illegal so clubbies cant have clubs ect
    we all have our favourites an we all see beauty in bikes that some cant as they say beauty is in the eye of the beholder ..thats why ppl modify their bikes different from others which is great seein we as humans are the only animals to be able to be individuals hey we all have a bag of jap bikes an they bag harleys we all bag stuff we may never have had our asses on but the bottom line is WE LIVE OUR LIFE THE WAY WE WANT ,WE RIDE WAT WE WANT AND RIDE WITH WHO WE WANT ..IT DONT MATTER WAT YA RIDE AS LONG AS YA RIDEING i only feel one thing when i see threads like this and its a feeling of sorrow knowin there are ppl that are in a hospital somewhere that will never be able to have the wind in their face again so next time ya out havin a ride an it pisses down or ya break down soare a thought for those who envy the fuck outta ya cause you are doin wat most crave in life BEING FREE
  • HogBag
    HogBag
    Nailed it ol Skool.
    Ol Skool have you ever played with nitros on any Harley's engines.
  • chrise1961
    chrise1961
    OL SKOOL you have summed it up, I have liked HD's for many years, but having ridden bikes for 35 years or more, only owned them for the past few years. WLA's. Pan's, Knuckle's, Shovel's, Evo's, Twin Cams or whatever, who gives a fuck as long as you are riding and enjoying the living shit out of what you are doing.... let's not worry about being petty.... I give a nod to every bike going the other way and if they don't nod back.. care factor of zero from me, I'm having a ball!!!
    and I know they are not in chronological order..... for the petty ones...
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    ok to answer a few here
    yes hogbag have played with it on harleys and jappas
    no i was ridding to broome in 79/80
    not a god buttttt my dads initals are J.C and he has (no bullshit) his birthday on 25th dec lol i got stuk with R.C arsey get it lol
    hey cooky lost ya number man give ma a call tonight bloke have a chat 0741578232
    i go to a few forums an see ppl whinein over trivial shit all the time ,,its rainin ,no bucks ,wifes pissed off,ect ect but most dont stop an think about how lucky they are ive lost some great brothers (club) and mates that only got to their 20s have also got few who cant walk or see an i got my stoopid heart probs which have really fucked me up but i cant ride an have had 2 rides only bout 10k since 2006 december but when i go see em or go to pay respects at the graves i thank ODIN GOD AND THE DOCS that have kept me here an kept me sorting bikes out so i can watch ppl smile after their bikes sorted way cheaper than shops oops stealers charge ..i envy all of you bein able to get out for a ride hey i loved jumpin on any my bikes an goin to cairns or south aust do big ride strait threw have the time to think about shit an clear me head also to meet ppl all over the country an help fix bikes ect my youngest boy isnt far off goin for walkabout he isnt into bikes like me has a old gl1000 he restored but its in storage he goin to travel while he can an do wat i done as a young fella maybe he might find a decent mullet to settle with or just plain have fun as i told both sons get out there b4 the gumbyment fucks this place its already half way fucked now an ppl are gettin more n more controlled by the filth an pollies
    ok im gone out to sort some powdercoatin seein as its stopped rain here more to come but lol have a top day fellas an mullets an live it the best we can ya only get one shot at life hey
    Q,, WHY DOES A WOMAN HAVE A SHOWER AFTER SEX
    A; SO SHE DONT TASTE OR LOOK LIKE A TOASTED CHEESE SANGER IN THE MORNING
     i don't mind eating toasted cheese sanger's in the morning  even with tomato sauce , it's the breakfast of champion's , but you have too eat them upside down  because the taste buds are on the top of your tounge if you know what i mean,      have a good weekend
  • philthy
    philthy
    Well said guys. A good ride does wonders to a persons soul. A ride,not a drive. Especially for those that CAN ride. Not fucked up forever/too old or something else. It makes me wonder how long riders are going to be around on this planet,before sickles are barred, like someone said. Yeah, do it while ya can.
