Online: beaglebasher, John.R, Hilly
LED Front Indicator Bulbs for Iron
  • bernd
    bernd
     Just wonder if somebody has experience with installing LED front indicator bulbs. After having upgraded to the LED headlight (really big improvement) I consider installing matching LED front indicator bulbs. Heard that I would need to install an equalizer to increase the load.  Would like to avoid this as I don't want to cut into the electric of the bike. Just wonder if this is true for the Iron as she has already LED rear indicators...
  • terroristone
    terroristone
    i fitted up some aftermarket mirrors/indicators that have LED's in them, not sure if they have inbuilt load equlizers or not but they work fine, why not just fit the globes and see?
    T1
  • 666
    666
     yeah i put mini led on the front ind on mine no probs no excessive flashing good luck
  • Ironman
    Ironman
    They have resistors built in the globe assy, so you don't have any issues.
  • bernd
    bernd
     Just a quick update:
    Installed LEDs from Custom Dynamics (part no: GEN200-A-1156). Looks and works great. No issue with fast flashing.
