Online: Stuart, Ultramick
Wide tire for 48 options
  • Bear2009
    Bear2009
    Hi Guys , i have a 2012 , 48 and wondering if anyone knows what is the widest rear  tire i can go on the stock rims (if possible) without  changing the handling too much  Currently runing the stock tires below
    (Michelin® Scorcher® “31” front and rear):
    - Rear – Scorcher® “31” 150/80B16 77H
  • Clement
    Clement
    Biggest rim/tyre Metz 880 marathons 160 60 18, 4.25 inch rim assuming all sporty frames are the same.
    Std rim would should be a 160 width with no swingarm mods.
    Clem
  • Bear2009
    Bear2009
    Cheers mate
