Online: speedzter
Scratches
  • -MaCCa-
    -MaCCa-
    G'day all,
                    In my challenge to install new apes etc by myself, it seems I have scratched the rocker cover.
    Would anyone have any suggestions on how to fix, or at least tidy it up? Damn cross over pipe. ended up with fuel all over me as well hahahahahahaha.
    Its been a while since I have worked on a bike myself, and although very challenging, it kills time so easy, as I get wrapt up in it all.
    Time seems to fly past. Learning quite a bit as well, and I am not even half way I think.
    See pic below.
  • AJ56
    AJ56
    Dremel with a buffing wheel on it. Or take it off and take it into a metal polishers and they will fix it up. Maybe wet and dry with brasso or something similar.
  • -MaCCa-
    -MaCCa-
    True mate, I was going to leave them there like a scar, but it seems I have some days to kill while waiting for a brake line, so thought I'd do something constructive.
    Can't ride the prick, so may as well tidy it up.
  • -MaCCa-
    -MaCCa-
    Cheers AJ56, I'll give it a go.
    AJ's on the money. Use some fine wet/dry first to take out most of the scratch's.
    Then polish the fuck out of it with a Dremel using a buff and cutting paste first then polish paste.
    Then polish the other one to match !
  • Rxes
    Rxes
     If you haven't got a dremal start with a 320 wet & dry and work your way up to 1200.
  • Daggs
    Daggs
     wet and dry then purple polish, mine came up like new when I had a similar, but smaller, scratch
  • conmore
    conmore
    +1 for Purple polish. Amazing shit!
  • Daggs
    Daggs
    Auto barn have it if they are near you...
  • -MaCCa-
    -MaCCa-
    i think I will check the purple polish out too. Thanks for the suggestions, I will try it on the weekend.
  • Daggs
    Daggs
    You could always ring them first to make sure, not all branches/states may stock all the same brands, anyway it's fantastic stuff
