Online: Stuart, Ultramick
hd progessive shocks
  • moonracker
    moonracker
    hi all has anyone tried HD progresive shocks, on a Heritage ?? if so are they much better than standard shocks most of my riding is two up bike only 16 months old and not real good  with she who must be obayed on the back .....nice sugestions please
  • moonracker
    moonracker
    ah well looks like no one can help ...sigh
  • oneball
    oneball
    Hi all...Moonracker,I recently put a set of Progressive RAP on my Fatboy Low.Its by far a superior shock than the stock shocks.Perfect for pillion or extra weight.
    Check out the progressive website , I just bought 430 series for my Dyna . I had a multiple choice of lengths , and a choice of heavy duty spring or standard . 250 lb min weight for heavy duty on this particular model . Bought mine from J.C. Motors in U.S. $799 quoted here , got them delivered for $421 !!
    Hi dev , your on the money. I weigh 230lb and ride 2 up most times.On the min pre load I have 1" sag solo , with pillion on setting mark 2 , also 1" sag . If I bought the standard springs I would just have to of wound it up a bit more. With my weight , and riding with pillion most times , thought hd spring on min side of  settings will work , Cheers , Tim.
    Bir late here, over the years i've used progressive shocks & fork springs. they are ok at the start but, the springs seem to loose tention specially in the forks. i've also had a few of there shocks fall apart. just thought i'd mention. this.
    I think if you really want the best you have to get someone to custom build to the bikes weight & the total weight it will carry.
    in Sydney a company called Shock Treatment & another guy called Frank Pons. both do this. costs more but worth the money.
