Online: Uncle Ho
Lowering options.
  • GTEEZ
    GTEEZ
    What is the recommended way to drop the standard rear height of a Softail? There seems to be various kits but which one is more suitable? I will be taking my forks of soon so while the bike is out of action I was going to drop the rear a bit.
    GTEEZ
  • GTEEZ
    GTEEZ
    Gotta be more options than that? I hate seeing daylight between the guard and tyre. Anyway, when/if I rake the front it will/should all come together.
    Any other gurus?
    GTEEZ
  • TJU
    TJU
    Gidday Robbo , you seem pretty happy with the Shockgun Shocks ..... can you recomend where to get them here in Australia , more specifically Sth East Queensland ..... am pretty keen to put them on my future Softail , thanks , Tim .
