Extended Upper Brake Line - 2012 Fat Bob
  • fatbob12
    fatbob12
    Just wondering if anyone out there has fitted extended upper brake lines to their Fat Bob... I was hoping to fit some 1 3/4" burleigh rollers but it appears there might be issues with extending the upper brake line??.... has anyone out there come across this issue yet?... apparently the issue is with the abs...
  • Bugger
    Bugger
    I havnt change my bars from standerd,
    But I was woundering the samething after looking at the brake lines other day, the ABS my be a issue.
  • Pappa Smurf
    Pappa Smurf
    May be a dumb question but why should the abs make it dificult to change a brake line?
    Especially an upper one.
  • fatbob12
    fatbob12
    Dunno Pappa Smurf... that's what I've been told.... I'm a technical/mechanical moron when it comes to this stuff.... I looked at the upper line and thought...yep... surely that could be changed to a longer line...from the manifold up to the lever.... apparently not that simple tho...or is it?....
    Looks like I might be waiting awhile before I can fit some burleigh rollers....bugger!!
