BIKE COVER
  • dav66h
    dav66h
    Im in the market for half reasonable cover for my bike the harley ones look good but are well over priced ebay has a heap you can buy from overseas im looking for one that is weather proof ,that i can put in my bags to take on rally's i know how much you guys & girls spend on your bikes and how much you love them so whats the story , whats good ,any ideas cheers
    HOW THE HELL DID I SPELL BIKE WRONG SORRY
  • Peter
    Peter
    I only use one when I am travelling and they are all ok as long as you don't buy shit. I find that at home they only attract moisture when you leave them on for days at a time.
    I use a rjays lined cover at home - $59.95 I think. I've had it for years now, however the new versions look different (bright silver rather than my dull grey) so I don't know if they are as good, or not.
  • Hoodaman
    Hoodaman
    Im just using an old car cover...it works but i know the RKC would be happier if it was felt lined....
  • toxic
    toxic
    at home it's called an awning  don't bother covering my bikes anywhere else.
  • gonzo
    gonzo
    I've been using a silver/grey Kel Pro cover for a few years. It's OK for traveling or when I'm making dust in the garage, but if I leave the bike covered for a day or so I find I get a thin film of something almost greasy on the bike. I wonder if it's the vinyl haze you get on the inside of car windshields. Don't know, but now I just leave the bike uncovered in the garage. That way, each time I go into the garage I get to ogle the bike a bit more. Good for the soul.
    For trips it's really useful, because I can leave the bike unattended overnight without people easily seeing what type of bike it is. That's my theory anyway. I got the large size cover that will go over my pack and screen.
    Gonzo
  • Bear
    Bear
    I Got a cover with the bike. Gotta say, I've never used it. The bike is rarely out of action long enough to justify unfolding it.
    Lol, I would never have expected such a "ghetto fix mentality" from a bunch of guys when protecting such a valuable investment.
  • Magilla
    Magilla
    Used to use a double bed fitted sheet for day use in the car park at work. With 30+ deg every day, as in 355 days a year, the UV will kill the duco, leather etc. As I said "used to use" as one day I knocked off work and when I removed the sheet it had a very big hole burnt in it. Now I used to make sure the sheet didn't touch any hot bits but some how that day I nearly lost the lot. Needless to say I chucked the sheet!!
    I have a full cover  that came with the "riders essential kit" I bought, but it is a large full cover, not heat proof, so can only be used when the bike is cool. Used once!
    http://www.harley-davidson.com/gma/gma_product.jsp?PRODUCT%3C%3Eprd_id=845524441849465&FOLDER%3C%3Efolder_id=2534374309149379&ASSORTMENT%3C%3East_id=2534374309149379&bmUID=1219053988803&bmLocale=en_US
    The other one is a half cover. Covermax half cover. Silver. Not heat proof either. Its not too bad as I only want it to give the bike shade. Basically hooks under the front guard, over the handlebars, tank and seat and hooks under the rear guard.
    http://www.motogearoutlet.com/misc.htm
    It has straps that hold the cover in place at the front and the rear straps I hook together and rest over the seat to keep it off the hot bits. So far so good.
    Just can't seem to find a genuine heat proof cover . It's not too much to ask. Mustn't be a market for 'em.
  • Curly's Lowrider
    Curly's Lowrider
    I use my loungeroom or if I have visitors we sit in the bike shed.
  • twincam88b
    twincam88b
    Used to have a Rjays cover for the last bike. I use 2 bed sheets now, bike is in a shed anyway. I think the cotton sheets breathe better, also the floor has a carpet square for the bike to sit on, helps reduce upward moisture.
  • dav66h
    dav66h
    Thanks guys for all the input and suggestions at the moment its parked in a carpeted garage covered by 2 double bed sheets to the floor and a blue tarp
    over that the tarp is for the salt air eats every thing here i dont know about you guys the more i hate polishing chrome the more i cover it anyway i think
    il just get a cheap for going away with ,its funny before i bought the bike it never rained for i dont know how long now you can rarely get a ride in without getting wet cheers.
  • Hoodaman
    Hoodaman
    The ol fitted bed sheet works a treat....
