Online: Stuart, Ultramick
06 fatboy rear tyre - advice - can I fit a wider tyre on stock rim
  • 06fatty
    06fatty
    I am running standard 16 inch rims on my 06 fatboy. The bald rear is a Dunlop D402 MU85 B16.
    A mate with the same bike and rim has a tyre which is wider at the tread level than mine, his tyre appears to splay out wider than my tyre on the same rim type.
    Can anyone advise if there is a wider tyre available to replace my stock tyre above (I have sent a text to mate but no reponse yet ....) and bike is being serviced on Thu.
    Any help appreciated.
  • 06fatty
    06fatty
    thanks Stewy - good info on the site.
    Fatty
  • 06fatty
    06fatty
    anytime Mr Mud ...Anytime ....  :-)
