Online: Stuart
Silicone? - LED Tail light
  • Deadwood
    Deadwood
    Howdy, bought meself one one the Kuryakyn tail lights a year or so ago and in that time the LED base has separated from the inside of the external case. Looks like it was glued in but a lack of response from Kuryakyn themselves has left me to pose the question here;
    Q. Would silicone be sufficient to reattach the base to the external case? If so which one, if not what would you use?
    Item in question is;
    Cheers.
    DW.
  • Retroman
    I have used black silicone to replace the globes in Heritage / Roadking "driving lamps"
    Worth a try, use clear if you need it
  • Deadwood
    Deadwood
    Thanks gents, will try sikaflex
  • als1200
    als1200
    Some silicone are very corosive to exposed wire.
