bolt sizes?
  • cdvreede
    cdvreede
     Replaced my rear shocks On My 2011 Fxdc With progressive 430`s leaving the CHrome cover that covers the Bolt off. Nuts of course are zinc plated And My Local Stealer tells Me There Is No Chrome or Stainless Version For it?
    Anyone Know Size And If CHRome/sTaInLESs is AvaILAbLe?
    SAME fOR THE bolts on the Chrome Dash....
    THnx
  • Gilesie
    Gilesie
    I usually take a sample in to a bearing shop, they will tell you if they have it in stainless or not
    Will be having 430,s fitted soon to my 2012 FXDC . Can,t  you use the original bolts and chrome top cover ?
  • cdvreede
    cdvreede
     Covers don't fit With the 430'S. Nuts do but are zinc and without the covers very vIsible....
    Thnx
  • cdvreede
    cdvreede
  • Daggs
    Daggs
    I've been away working, just got home, had a look, mine are not chrome just a slightly shiney zinc plated...  :) .... sorry about that.
    I would fit stainless or chrome without a worry, just use some blue loctite on them.
     I run them without the covers too
  • CRUSTY
    CRUSTY
    I just cut the slot on the covers with some tin snips cannot
    Even tell and used a stainless dome nut, the dome nut has fuk
    All pressure on it, it's only really there to stop the shocks
    Slidding off the bolts !
    Dealer fitted 430,s to my 2012 FXDC , they trimmed the chrome cover to suit , looks stock .
  • markkoby
    markkoby
    I would not use stainless bolts on any load areas on bike.
  • cdvreede
    cdvreede
     done - turns out the moco sells 1/2in chrome acorn nuts . perfect replacement for the stock zinc nuts. looks nicer without the chrome cover and since it's only a retaining nut i feel that i didn't weaken the area...
    now try to find chrome versions of the button bolts holding down the dash on the tank...
    thnx
