Online: Rextheute2022
speedo cuts out
  • brush
    brush
    somedays i can start bike and speedo wont work,stop down the road switch her off restart works fine,anyone got any ideas on what to start looking for. 07 dyna wide glide. cheers  BRUSH
  • one_oak
    one_oak
    I had the same problem on my nightster, my problem ended up being water in the connectors under the tank, pulled them out and dryed them all good.
  • poverty rider
    poverty rider
    I had a similar problem with my 01 FXD, the regulator was the culprit.
  • Isaac
    Isaac
    My speedo problem included the indicators. It was a loose connection in the loom - check all.
  • HogBag
    HogBag
    Would you have a thundermax tuner on the bike.
  • brush
    brush
    thanks guys ill start looking. no HOGBAG i run a screaming eagle pro race tuner.
  • HogBag
    HogBag
    The Tmax had problems with the speedo dropping out.
  • Rxes
    Rxes
     I had that problem, went through all connections and fuses and put electrical grease on them, sorted.
