Online: BURTO, beaglebasher
'12 tuner
  • marce
    marce
     hey dudes,
    what are you 2012 bolkes doing for a tuner on your new bike(you could'nt all be rding around with stock pipes)?
    could you tell me your plans if you're waiting for the release of new tuner models?
    marce
  • marce
    marce
     yes i would like to do it myself,try different things out on the bike,and hopefully not spend $ on the dyno.
    what do you recomend hilly ?
  • flacky
    flacky
    Marce I just went the V&H fuelpak to match the slipons and air filter.
    I just wanted something simple that works and I can upgrade/change the settings as parts change without dynos or laptops
