progressive 422 RAP
  • oneball
    oneball
    Hi all...I replaced the standard fatboy low shock with the Progressive 422 RAP.All i can say is im very happy indeed.These shocks are far superior to the standard shocks in every way.The days of bottoming out is now a distant memory.Ideal choice for someone who needs rear suspension that needs to be adjusted for when doubling.Adjusting the shock firmness is as simple as turning the dial.Installation was simple.
  • oneball
    oneball
    Hi all...I paid $618.00 landed here in Au.Got them thru M&M cycles,Great customer service.
  • oneball
    oneball
    Hi all...Robo61,Yes it lowers the low heaps lower than standard.Although i havnt tried it.
  • thebald1
    thebald1
     I just ordered mine from the States for my Deluxe, glad to hear your happy with them, cheers TB1
  • Rocky2010
    Rocky2010
    Stock Harley shocks are of poor quality, on both of the Harleys I have owned after twelve months the shocks have needed replacing.
    http://www.jpcycles.com/product/700-351
  • thebald1
    thebald1
    Pricewise the Progressive Premiums at just a tad over  $400AUD...landed i thought was a bargain. JMHO
     TB1
  • oneball
    oneball
    Hi all...mon 4u2c,I think the 422rap lowers 50mm lower than a standard Fatboy.The 422rap definately lowers much more than the rear of the Fatboy low.
  • thebald1
    thebald1
    Had mine fitted, wow what a difference, doesnt wallow anymore, smooth, and adjustable 2'' lower,
    best 400hunj spent so far,
    Cheers TB1
  • thebald1
    thebald1
    Hey Sparra,
    Joe Major:
    WWW.AMERICANCLASSICMOTORS.NET
    AIM/AOL ID: ACMPARTSMGR
    315 Big Road Po Box 298
    Ziegleville, Pa 19492
    610 754 8500 x 102
    610 754 8501 Fax
    INTLQ1
    They also have an eBay store
    cheers TB1
