Online: Stuart
Nail in tyre
  • The Ox
    The Ox
    Hi just pulled out a 4 inch nail which was imbedded in my rear tyre, thankfully it did not puncture the tyre  my question is this will it be still safe to ride around with or will i need to buy another tyre.
    ps. The nail was imbedded on the side.
  • The Ox
    The Ox
    tubeless Rodders
  • fattatt
    fattatt
    FLICK IT mate.
  • FLSTC
    FLSTC
    probably should err on the safe side
  • Hound_Dog
    Hound_Dog
    Replace it asap.
  • The Ox
    The Ox
    Thanks guys i guess i will be buying a new tyre very soon, i've nearly done 8000 km on it anyway. What is the average price of a rear tyre fitted.
  • The Ox
    The Ox
    Just got quoted $351 from the stealers fitted WTF.
  • ductor
    ductor
    I get around 12000 to a rear tyre(200mm softail) but I paid over $400 at Gasoline Gulley
  • The Ox
    The Ox
    Tyre size is 200 mm Dunlop d407
  • BURTO
    BURTO
     Personally, if it's still holding air, I'd keep riding it.
    If it was the front tyre, I'd replace the bugger.
    Put a tube in it if your worried!
    Burto.
  • Rocky2010
    Rocky2010
    I would replace it, much cheaper than a trip to the Hospital or worse.
  • fatasspaul
    fatasspaul
    Swap bikes with your mate,ride it through the mountains one day, if no probs then you will be fine!
  • gsh
    gsh
    How cashed up are you, nothing worse than a high speed blow out. Until you get it fixed I'd stick to legal speed limits.
  • The Ox
    The Ox
    Thanks guys for getting back to me, i've decided to  buy a new tyre next week so the question is what brand of tyre should i buy.
  • als1200
    als1200
    I've been running with a plug (not in the side) and it has not been a issue. It was a new tyre at the time. But if had done those sort of kays and your not sure just change it, it will make you feel more relaxed. Shit if I get a flat I'll just phone robo to pick me up!
  • HWG
    HWG
    Rear 200 Dunlop should be about $350 fitted.
