thunder max lead?
  • jim76
    jim76
    Does the thunder max unit come with the cable that links the computer n the bike or do i have to buy a lead seperate? thought i read in here somewhere that u have to buy one
  • jim76
    jim76
    thanks scotty for the reply
  • kingchops
    kingchops
    Although keep in mind if all you have are USB ports on your pc/laptop you may need an additional serial to USB cable as the Thundermax cable only connects to serial ports.
  • jim76
    jim76
    have no idea what a serrial port is n if my computer has one but will ck it out
  • jim76
    jim76
    thanks for the pics KC cked out my laptop i will have to get an adapter i only have USB ports thanks again for all the info im sure i will have a few more for u all
  • kiteman
    kiteman
    Save yourself some time and phone the IT shop first! The Serial to USB adapter is not so common and costs about $40 AND you need to install the software from the disc supplied. It's not too hard............but thenI haven't tested it yet!!
    good luck mate,
  • Fantm2
    Fantm2
    Got my adaptor cable from AandR Computers off the shelf for under $30.00 from memory (18mths ago).
