cams & tts to PCV
  • Train
    Train
    Hey fellas, just thought id put up my experience with this tuning caper.
    I'm not here to bag TTS because i know from all you blokes that really know how to use that its a top unit. Just that it wasn't for me. Even with blokes like Hilly and Ozroder helping me out, I couldnt get my head around it.
    Anyways I had cams put in and arranged for Brian at EBT to put it on the dyno. After some discussion we decided on the PCV and a custom map.
    I picked up my bike this arvo, the bike has never felt better. Its so crisp, Brian got rid of every bit of decel pop and my bassani firesweeps popped like a bitch. The bike runs like a cut snake. I'm rapped with it now and feels like a new bike.
    This was an expensive lesson for me. I should have went with a different tuner and have someone that knows how to use a dyno do it from the start. So i thought id put this up for some of the other blokes that aren't to cluey on the tuning game and sometimes its not a bad thing to let the pros do their thing.
    Hope it helps some of you others out there
    have you done much with your pvc before getting this tune?
  • Train
    Train
    cheers fellas
  • Train
    Train
    Thanks for all your help bro
