107 build in progress
  • Spinner
    Spinner
    I am in the process of up grading my mild 103 + cam kitted dyna with a Tman 107 kit build will be as follows.
    Bike has already been fitted with a 30t front pulley and a 68t rear.
    Tman forged pistons +19cc dome
    Tman stage 4 heads + vulcan support plates + S&S roller rockers
    Tman 662-1 cams with upgraded cam bearings
    SE tapered adjustable push rods
    Fueling cam plate + oil pump + race lifters
    55mm HPI throttle body with 1.8 manifoild to suit his stage 4 heads
    VPC clutch
    D&D fat cats with big bore baffle
    Should get along quite well, will let you know the outcome after it has been to the dyno.
  • Spinner
    Spinner
     Bottom end had .002 runout Tom from tman said it would be ok if the bike was ridden without flogging to death all the time or dragging it a lot. He has built a fair few bikes with these kits without to many problems he said the cranks aren't as bad as everyone makes out. Anything bigger he recommends a crank rebuild I suppose I will find if he is bullshiting me in the near future.
  • HogBag
    HogBag
    Sounds like a great build spinner. Have you got a heavy spring to drop in under the VPC because I think your going to need it with the power that's going to put out.
  • Spinner
    Spinner
     Already got a se spring in her now will us it  with the vpc
  • BURTO
    BURTO
     Sounds like fun!...........reckon the hardest part may be not floggin it to save the crank!!
    Interested to see the results too!
    Burto.
