id have to disagree with the negatives on this one , as ive just got a 883 converted to a 1250 nsr kit in it , i have a stockish 883 the missus rides and the 883-1250 i bought , there is a huge diff , these are both 2007 bikes , after getting of the bob i sold with 130hp i dont think there would be much in the 1250 upto about 100kph, just under 80hp, i do no that this 1250 has huge compression as it need a tricky way to start it up , it will never start with one hit of the starter, needs like a doubble hit on the starter
+3 no negatives and i am getting better fuel economy when cruising, mind you i do not have the tank lift done.
Cheers,
Clem
Waz you are exactly right with most of the 1250 kits using stock heads the compression goes up to 10:1 or greater it's all to do with the reverse dome pistons.
Thanks for the info as I was curious if you had been able to use your heads un-modified because when I got the Andrews Cams kit it recommends valve mods for N4 Cams and greater but I remembered you are running N4's from your tag line so I thought I would ask. I emailed Gary from Andrews Products in the States and his reply about N4's stated to check the exhaust valve clearance in relation to the piston, which I will do, hopefully there will be enough clearance with the Revolution Performance 1250 kit I'm using.
