Tyre repair kit
  • The Ox
    The Ox
    Hi does anyone know of a good tyre repair kit.
  • FLSTC
    FLSTC
    there are plenty of kits out there but i prefer the sticky "liquorish" sticks ( for want of a better description ) . just get the basic kit , make sure you have a pair of pliers , and its cheaper to buy seperately C02 16gm canisters .. you will need 4-6 to properly inflate a harley tyre .... OR get a portable tyre pump to run off a power socket
  • The Ox
    The Ox
    Thanks
  • PK2
    PK2
    You dont need patches unless you run tubes - and then its easier to just carry a new tube.
    The plugs are the go for tubeless - I carry a kit in my 4WD all the time and have used it probably 10 times over the past 5 years (we do a lot of camping and outback trips,also work on building sites) Its great not to have to put the spare on! I've NEVER had a plug leak.
    Mind you on the HD I'd get the tyre replaced asap - dont need rapid deflation!
    Great for getting out of trouble though!
  • Annie888
    Annie888
     Thanks for the site. I need a new kit
