Starter motor
  • Cisco
    Cisco
    Can anyone recommend where to get a good deal on a starter motor for a Dyna Super glide custom- 2008.
    The motor has been upped a bit and the current starter is just about shit.
    Any suggestions are welcome.
    Cisco
    M8 save your money just put new clutch in your stock starter.
    i have 01 dyna with 225 or 230 pound cranking pressure?? and it has killed three starters i just get new clutch put into starter. i have the older evo starter ring gear as beefier teeth i also have screamin eagle decomp valves that i have to push down b4 i start , they help. but i think true fix is the S&S easy start cams just depends on your personal build. a big inch motor EFI to really tune for performance i think you need an easy start cam or your just going to go through starters motors or ring gears. the decomp & electric comp releases don't bleed off as much pressure as the easy start cams. just finding the best crind cam is the problem.
  • Cisco
    Cisco
    Thanks krash advice accepted.
  • als1200
    als1200
    It's a shame no one does a high torque starter for them! Anyone tried some of the brands out their that make claims of them being better than the STD one?
