Online: wildchild, Hilly, flstc08
2003 FXD Braided Brake Line
  • Maturecruiser
    Maturecruiser
     I want to replace the front brake line on my 2003 Superglide. Single left hand side disc. It is currently a rubber hose and pipe combination. The accessories book lists a stainless replacement line but nothing in black and the dealer confirms they do not make 1. I have searched aftermarket web sites but none advertise a specific listing for this model.  My option seems to be to buy the cable and then the banjo fittings.  It then gets interesting with the banjo ends being either 10mm or 12mm (I cant believe that a Harley part is in mm either). I would appreciate some help as I will have to buy either Eastern States or overseas. One supplier suggested I remove the existing cable, send it to him and then he would make me a replacement. That was about 2 weeks worth of post time.
  • Maturecruiser
    Maturecruiser
    Thanks Grotty & uglyfish, I will email them and see what I can find out.
