Online: BigKangaroo
Siren won't shut up !
  • Scruffy
    Scruffy
    Have a 2000 Deuce with a "The Immobiliser' alarm fitted. When the battery is connected the siren is locked on. Only way to shut it up is disconnect the battery, But get this - if I de-activate the system using the fob, the bike starts and runs just fine - WTF ! All the time the siren blaring - any ideas??
  • sonnyc
    sonnyc
    fob need new battery?
  • Scruffy
    Scruffy
    Thanx for the reply Sonnyc - been there - done that. All seems to work fine - just the bl#%dy siren won't shut up.
  • issues2
    issues2
    New TSSM (turn signal security module) required.
    My 2001 wideglide would set the alarm off riding along,occasionally shut it down
    New module,problem fixed
  • Scruffy
    Scruffy
    Thanx for the reply Issues2. What i'm thinking is that the motion sensor side of the operation has failed and this has caused the siren to remain on. Therefore there must be a mercury switch either in the alarm module or somewhere else on the bike that is kaput. My question therefore is, is there a motion switch in the TSSM? I have unplugged the siren (ah the serenity) and the bike starts and runs fine.
  • issues2
    issues2
    Yeah mate it has just collapsed
    I have 2001 Wideglide,my wife has 2001 lowrider so I swap electrical parts to check probs on either bike.
    Put it on the stealers computer & it will tell you the same
