Online: Stuart, Hilly
whistleing sound
  • phattstump
    phattstump
    Hi All,
    slowly sorting my bike out  ( 87 heritage softail )
    BUT
    I need to get rid of the whistle from 80K's upwards, it's driving me mad
    think it's in the headlight or around that area somewhere,
    anyone else had this problem
    regards Stumpy
  • Rxes
    Rxes
     Does it start at the 80km and stay as you increase your speed or fade off?
  • phattstump
    phattstump
    Gets louder as I increase speed
    it's like the old HK HT Holden coming down the road
    fukin anoying
    the early g/box was a bit on the whining side of noises they sorted it out in 1996,   but i would check the box oil , pulley's etc , pri chain tension  1st  +  wheel bearings  F/R all the important thing's  1st ,   then you know what your bike con'd is like anyway
  • AJ56
    AJ56
    Btcha it's the headlight bezel...... Try putting foam in around the bezel to see if that takes the bugger away
  • phattstump
    phattstump
    Macka71 I tried putting one finger in my ear but it was still there,
    Daddyracer, when i first got the bike I dumped all oils, gearbox, primary, engine and forks
    first thing I do when I get a second hand bike, peace of mind
    AJ56, your right on the money, it is coming from the headlight, or cowling
    I was hoping someone had a exact place that is was, but yes will start around the headlight with weathershield tape
    thanks
  • Rxes
    Rxes
     Could try a little clear silicon in the gap of the head light clamp ring, and look for any gap / hollow section that could catch wind like edge of bezel / cowling at forks, put duc tap over than go for ride to test. Post a pic of front section.
    the tin ware make's a lot of noises on fat-boy's & hero's , as long as the bike's safe
  • PK2
    PK2
    Are you smiling too much and its whistling through the gap in your teeth???
  • ductor
    ductor
    Have you tried changing helmets, not as silly as it sounds.
  • AJ56
    AJ56
     That is more than likely the Primary chain.  Just settling in and will tension up as the chain stretches and the adjuster jumps up a knotch.
  • Train
    Train
    Cheers AJ ..... meant to write 16000ks .... would it still be the same thing
  • HogBag
    HogBag
    Might be bunch of girls giving you the wolf whistle when you ride.
    Put a pillowcase or two over the headlight and go for a ride - at least you'llknow if its the light. If so, stick on some tape, a section at a time, to see where its coming from.
    1987 is a manual pri chain adjuster have you check the slack on the chain , these early models have a noisey g/box that howls/whines esp in 3rd & 4th,    if this bike has only 16,000 klms & is 25 yrs old that is less than 750 klms a year ,    the pri chain should have about 1/2 inch slack cold  or a bit less hot but not tight i always check the pri chain hot as then you know what its doing @ opperating temp
  • Train
    Train
    Cheers DR56, My bike is a 2011
  • phattstump
    phattstump
    Went for another ride last night and played with the headlight,
    there seems to be 2 whistles
    one from the headlight which I will fix with extrusion tape ( door double sided tape )
    and the other is from the bottom of the cowling,
    so getting closer to the problem
