Went out for a ride yesterday and all was going good until the bike just died,
all lights, blinkers, horn everything works but nothing at the starter switch,
it's like the kill switch has been switched off,
I have checked the switch and there is no power to it,
there is power at the ignition ( grey wire goes to kill switch) but no power at the join in the wires at the bass of the handle bars,
so under the tank I'm guessing is where the problem is,
is there a fuse or alike under there
any ideas
regards Stumpy
Haven't PLAYED with any other harleys than my own, no fuse on mine, sounds like a connection fail, you are going to have to lift tank and look. (I take it that there is power leaving the ing; switch??)
