Online: Stuart, Hilly
Storage 98 softail
  • Keesh
    Keesh
    Long time storage taking the weight off the suspension, putting a timber block underneath the centre of the frame along the cross member between motor and gearbox. Is this going to put any stresses on the frame etc
  • Keesh
    Keesh
    6 months
  • Keesh
    Keesh
    so either way theres no stress on frame or anything else no harm done ? yeh it is long 6 months without riding
  • Keesh
    Keesh
    its got nothing to do with the tyres if you read i said the load off the suspension
  • blueystar
    blueystar
    just make sure the valves on the tyres are at the top the air will stay in your tyres longer
  • Keesh
    Keesh
    dunno you tell me ?
  • Keesh
    Keesh
    Cheers Bluey
  • AJ56
    AJ56
    Your tyres will probably loose a lot of pressure sue to lack of use, the molecules in the tube/tyre are not being disturbed and as such will allow the air to seep past. That's why you see tyres on push bikes deflate without use over a period of time. The oil will drop down into the motor over that period, so drain your oil tank and put the battery on trickle charge, (if you have a battery booster then that's better) Other than that have the bike covered to keep the dust off.
  • Rxes
    Rxes
     Could always find a mate to come over and check on it and take it out for daily "walks"
  • calais
    calais
    I was told to just wash and polish the bike, throw a blanket over it, plug in a battery maintainer and thats it.
    I have had to leave my bike for months at a time and Ive never had an issue.
    My only other advice is to make sure wherever you leave your bike is always going to be completely dry.
