Online: Stuart
Steering head bearing grease.
  • conmore
    conmore
    Hi there
    I was wondering from experience what most forum members use for lubricating the steering head bearings.
    I used to use a Mobil lithium based grease HP Special which was coloured blue amd water resistant etc but Mobil service stations don't exist in city areas (I'm in Geelong) any longer and I called Repco and Bursons and they don't stock it.
    Popular alternative?
    Cheers :)
  • V2Evo96
    V2Evo96
    I have a tube of Caltex (I think it's labelled no. 2) red HD grease that may be heavy enough not to 'run' in high temp applications. I haven't tried it in the steering head as yet though. To the touch it's very tacky and might work, but I can't prove it.
  • Rxes
    Rxes
     I was told that any marine grade bearing grease is good enough, not had any problems with it.
  • the_mongrel
    the_mongrel
    I have used a good Moly Based Caltex grease. In the white tub with the red lid. :)
  • BURTO
    BURTO
     would think any high temp wheel bearing grease would do..........is all I've ever used!
    Burto.
    +1 on wheel bearing grease.
    This has served me well :
    http://www.nulon.com.au/products/Specialty_Products/Extreme_Performance_Grease/
  • conmore
    conmore
     Hi there
    Went the Nulon. Thanks.
    HD must only pack the bearings with grease and little or no grease in the steering stem. I used over half the tube to hear a faint "squish" of grease coming out the stem..
    Cheers :)
    i'm doing my steering head bearings now. i pull front end off so i can inspect them then repack bearings. i got some Belray waterproof grease, make for the job. Belray always have good bike lubricants.
  • the_mongrel
    the_mongrel
    +1 ^
    If the bearings need greasing, then it might be a good idea to inspect them at the same time. Pointless greasing a stuffed bearing.
    the Belray Grease i used is real thick & sticky, supposed not to run. it sure seemed better than the Kendal i used last time , & the Kendal was good. i'm now going to remove swingarm and inspect the bearings re pack with this Belray Grease.
