FXD Brake improvements??
  • Sledge
    Sledge
     Hi Guys I was wondering if anybody has some ideas as to how to improve the stock brakes on my 09FXD
    I have had a look around and have not turned up much in the way of ideas.
    The power is ok but find myself with the thing wide open often and so I want to do a power improvement, but before I do that I would really like the bike to stop much better than it currently does.
    Cheers Sledge
  • KELD
    KELD
    1: braided lines
    2: floating rotors
    3: performance compound pads
    4" re-bleed with better fluid
    DONE!
  • Pappa Smurf
    Pappa Smurf
    Braided lines & Brembo calliper.
  • Sledge
    Sledge
     Thanks for the feedback fellas.
    I probably wouldnt bother changing over the front end to get twin disks, would sell the bike and buy one off the floor with them if that was the only way to improve braking.
    I have looked for the brembo callipers but have not found then to suit yet, maybe I'm just not looking in the right places.
    I have already put better pads on the bike but would still like better braking.
    Has anybody fitted braded lines and if so, how much did it improve the braking?
    Cheers Sledge
  • KELD
    KELD
    I have done all 4 stage improvemens below and it stops like a superbike!
    1: braided lines
    2: floating rotors
    4: re-bleed with better fluid
  • Sledge
    Sledge
    Thanks Keld,
    I already have a floating disk (stock ) on the front
    so I will head into the stealers and see what they have to suit.
    Maybe just get a pair of floating roaters that match,
    any preference/ ideas on performance pads
    Cheers Sledge
  • Underground
    Underground
    Coming from sports bikes, ones which way just over half what my Dyna does, I was pretty shocked at the little 2 pot caliper sitting up front my it's lonesome...
    I thought I might have to fred flintsone the bike to get it to stop.
    Good info in this thread!
    Hi Scouser , how can I PM you ? , Cheers , Tim.
  • Sledge
    Sledge
     rode in to Harley heaven today and got some new pads ( no not harley ones) and asked about the braded lines, none in stock so will see what I can find on the net over the weekend.
    As far as floating disks the one currently on the front of my bike is the only one avaliable apparently.
    a rear floating disk is avaliable but nothing to match the front.
    Cheers Sledge
  • nhb006
    nhb006
    Can anyone suggest who may have a set of lyndall golds in stock to suit 2011 fxdb?
  • nhb006
    nhb006
    Yhanks Scouser
  • phatsphil
    phatsphil
    hey sledge all good info on this site but none that lead you to get the brembos here is the spot  1130.com its a septic site for them porchadavidson owners (VROD) You can source all the brembos an twin fork legs an maybe even a twin disc wheel FKN CHEAP dont tell evary one
  • FastHarley
    FastHarley
    Try this 320mm MMC & real Brembos (Pair of them).
  • grim
    grim
    Hey hey Fastharley thanks for the link to howard@motorcyclemetal.com they certainly have some good gear there mate, hmmm just might be able to get the kingy to stop as well or if not better than me mates victory cruiser---cheers Grim
  • FastHarley
    FastHarley
    A bagger with a fender just setting on the tire, just for reference.  These are 320mm SS real floating rotors.  I use these Brembos a lot, they are rebuildable, and work well.
