Online: DC67
Gen 3 Dobeck Performance Tuner
  • FB105
    FB105
    Hi all
    I just bought a 2008 Fat Boy and it has a Gen 3 Dobeck Performance EFI tuner installed.  I am about to install Bub Rinehart Xbacks, has anyone out there had any experience with this type of tuner.  You can manually increase or decrease the fuel for low, mid and top end. Does anyone out there have a recommendation.
  • gforce
    gforce
    What exhaust did the bike come with?
  • FB105
    FB105
    Hi, thanks for the reply.....at the moment it has stock pipes fitted, so I could get it registered in WA
