suggestions for space left where horn was
  • Black1
    Black1
    I'm after a few suggestion for something to add to the spot where the horn was located above the motor any suggestions.  I relocated my horn behind battery as I dont like the look of the bell horn.  I still want to see the motor, was thinking of a plain Harley badge to cover where the bolt was (small round or oval shaped).  I've attached a photo of area so it makes more sense.
  • nhb006
    nhb006
    How did you get the rubber mount out? Mine wont budge! Also how relocate the horn?
    Drill a hole to mount the horn in the back of the battery cradle and mount it there?
    I havent had the battery out to see whats behind it.
  • markfxd
    markfxd
     Nitrous solenoid
  • Isaac
    Isaac
    A mate has that eagle head on his Road King and itza quality lookin' bit of gear. But I like the forum badge idea - you've removed a big chunk and the engine is now the focus. Why hide it again?
  • Black1
    Black1
    Red
    Thanks for your informative comment, nice to see somethings never change.
    Thanks also to the other responders.  I will probably find a badge of some sort, may even consider the forum one when I get a chance to check the dimensions.  The eagle did look pretty flash, however would probably be a bit over the top.  I am also trying to restrict the cash I've been spending on the black1.
    nhb006, there was no horn fitted to my bike when I got it, so it didn't have any rubber mount problems.  I got the horn relocation idea from Kingchops post on the forum.  Nice looking bike you've got.
    I have attached a link to his thread, very informative with photo's.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=24&tpage=1&view=topic&postid=173193#173311.
    I just purchased a cheap $15 ebay horn and seperated the wiring so I could relocate it.  I then hide the horn up behind the battery box and under the seat using a couple of plastic wire ties through the holes in the battery box to secure (no drilling required).  Horn sounds like shit but who cares as I never use it and only needed it to get my bike licenced.
  • Daggs
    Daggs
    I just made a small stainless bracket that holds the plug wire fits nice.
    I hated the stupid cowbell
  • Daggs
    Daggs
    Cowbell is great on a drum kit, not on the side of my bike...
  • Daggs
    Daggs
    Nah, the horn is hidden behind the cowbell..
  • Underground
    Underground
    The world needs more cowbell.
  • Daggs
    Daggs
    cowbell wont get the proper sound holding it like that... will be muted lol
  • Harvey
    Harvey
    How about the coil.
  • Harvey
    Harvey
    Nothing. Not sure about Dynas but on the softails you can remove the post that the coil is fitted to.
    Shorter coil wires and less clutter around the oil tank.
  • Daggs
    Daggs
    i relocated my horn as i didnt like the cowbell and i also wanted to see more of the motor so me personally, i wouldnt be puting anything else there
  • nhb006
    nhb006
    Finally got that stinking rubber mount out. - Red locktite on it!
    Just cable tied my lead to it.
  • Stewy
    Stewy
    Mabey put something better near where the cowbell was.
    Does the job
  • Stewy
    Stewy
    Bayonet came from disposals Macka    .$100
    Fabrication and fitting by myself
  • Isaac
    Isaac
    Bayonet! Love it!
  • Stewy
    Stewy
    Hmmm  They can go for there lives. See how many bits and taps THEY break. (Fucken hard stainless)
    File and hacksaw dont even scratch it
    All copyright donations to stewysbenevolentfund.com
