Online: Retroman, Stuart, baldy1450, Hilly
REAR TYRE CHOICES....
  • pan head
    pan head
    WWW Motorcycle Performance Front Tire 130/90-16 White Wall Shinko New [script removed]
    Lookng into a new rear tyre, anyone got a shinko on the rear, they do look a bit square compared to the Dunlop white wall above,
  • 883n Harley Convert
    883n Harley Convert
    Pan, I run Avon Venom's, great tyres, no issues @ all!
    There are three types the Wide Whitewall (what I have); which is directly below
    Then the narrow white wall
    and if you're just running one...................go this: The Avon Ganster!!
  • pan head
    pan head
    What do they look like on your bike.  Dont know about that Ganster, looks like a harder tread or is it just the photo.
    883n Harley Convert
    Will post one when I get home
    883n Harley Convert
    Thats what the wide white walls look like, 21' front and 16' rear
  • pan head
    pan head
    cheers looks good,  even better with the raw tank.  Great idea.
