power vision
    Has anyone had much to do with a power vision tune for a 103 cube street glide? Have a decent tune at the moment but interested to see if anyone else has a different idea.
    not totaly happy with it pinging(very slightly) at full throttle from around 5000 to shift around 5500. Not sure how to see if its front or rear cyl that needs some timing adjustments.
    The map is from Fuelmoto that they kindly sent me to suit mods outlined to them. As the unit was purchased localy Jamie was very kind to supply the map currently running, just need some direction regarding the slight pinging mentioned. Any suggestion?
    Dyno is not happening at $495. Looking for someone that can tune the old way,original question still stands,can anyone tell me how to tell if its front or rear cyl that is having the timing issue?
    Not sure if you can do that as the powervision locks the ecu to that powervision only, not sure if the std ecu has the ability to be coded to separate devices at the same time? As far as data collection the powervision is quiet handy and very simple to use. Its just learning to interpret that data thats proving difficult!
    Is there anyone running a powervision on a 2012 streetglide on the forum?
    any one running a 2012 103 with a power vision tuner and vance and hines slip ons and s/eagle ventilator i have a good tune to give you if you want it.
  • steel cat 41
    steel cat 41
    Pauly Iam running power vision on 2011 streetglide I got it pre mapped from Jamie but is running a bit rich also fitted with v&H slip ons
  • steel cat 41
    steel cat 41
    Check your pm for my contact details to send you the tunes
    Hi Mate , sent you a pm , do you want the tunes? Contact me via the email address in the pm, happy to walk you thru the process
  • steel cat 41
    steel cat 41
    Thanks I have been away that would be great
