Online: speedzter
Touring Handlebar?
  • Rocky2010
    Rocky2010
    They should fit, but if they are internally wired that makes the job so much longer to install the wiring, also you may have to change the clutch and throttle cables to suit the extra lenght if you need different cables.
  • glassyflower
    glassyflower
     thank post
  • glassyflower
    glassyflower
    thank post
