boys ze little pig, she is broken. hit the starter and just get a click noise (real dull sort of click though - almost a clunk) after doing some research it sounds like it may be starter, relay or soleniod related. i fully charged the battery to make sure that did not change anything. still the same.
so im about to start working along those lines - relay then soleniod and then starter. just wanted to check if anyone had a different thought on what it could be. any help guys is really appreciated. she is a 93 sporty.
Yep... similar thing with me also, replaced battery and all good. Keep us posted on the outcome.
I had the same problem in December...it turned out to be the Stata...borrow a battery from someone, and after you start your bike, put a multimetre on it to see if it's charging...
