2011 street bob, where will 200 tyres make contact?
  • gidgi
    gidgi
     I went to put on a 200 on my 07 streetbob & the guy said they would go on but they would balloon out on my 5-1/2" wheel making the ride suk
  • Daggs
    Daggs
    i have no idea about the sceaming eagle 200 but the 200 avon and metz are fine on a 5.5" rim, ive had them both and the fit the rim perfect and ride VERY VERY well
  • calais
    calais
    Sounds good, but did they cause any issues up inside the rear fender with any of the bolts and shit up in there?
    I was told by someone who I presume to be a wanker that even a 180 wouldn't fit up because of the fender strut bolts........
    I'm keen to throw a wider tyre under there once my Dunlop 160 wears out, so it'd be nice to know.....
  • nhb006
    nhb006
    Stocker on a street bob is 160, i presume you mean the SE180, which is stock on wideglide, not SE200?
    180 is straight on, 200 take a lil work.
  • Gilesie
    Gilesie
    How many Ks on the old Tyre GuyMc? I thought mine was close and i just put another 1600 on it this past weekend
  • nhb006
    nhb006
    Ah. yes, to my knowledge it will fit in the guard but I know you will have to use button head set screws and acorn nuts to hold the rear fender on, and relocate the indicators
  • Gilesie
    Gilesie
     10,600 and its about due, doesnt seem to be a lot of choice in that size, its the front one that annoys me with its grinding.
  • Stewy
    Stewy
    Check this chart out it might help you make a decision.
    I fitted a 170/60x17 on my streetbob
    It is the largest you can fit on a standard rim. Except SE180 made to fit standard rim
    Cheers    Stewy
    www.hdwheels.com/Product.htm
    Hope this works, first link i have done
  • Stewy
    Stewy
    BUGGER
  • sime69
    sime69
    Mate I don't think a 200mm wide tyre will fit. I have the SE 180 on a 06 Dyna, lowered an inch....I assume the guards havent widened in recent years like the Softys did.
    reckon I have 4mm clearance on each side in the rear guard  and yes there's plenty of wiring and bolt threads up inside for the tyre to hit if you bottom out.
