saddlebags for 07 FXDL
  • oldbiker
    oldbiker
    Does anyone knows of saddle bags that does not need relocation of the rear turn indicators.  I've seen pics foxcreek website of the throwover kind but could not be sure if it needs bracket (so that it does not come in contact with the tyre).  Any info would help.
  • calais
    calais
    I bought set of bags from Fox Creek.... They make a bag which suits Dyna's so that you dont have to relocate your indicators at all. Just drop them an email, the Bloke who runs Fox Creek is a nice bloke and can pretty much make what you need.
    I also bought a set of Kromewerks saddle bag supports which had a replacement boss for my indicator stalks to mount straight onto. So they are in the same position, just an inch further out on each side.
  • swbob
    swbob
    Try this guy,i just bought the battery bag and i am very pleased with it.
    Hope this helps
    http://www.badgcustoms.com/solo-bags.html
  • calais
    calais
    I dont see why they wouldnt....... I would have a quick check through the Khromeweks catalogue though just to be certain.
    I know the ones I bought didn't mention that they actually fit my bike it just had Dyna 04-09 or something like that on the packet, I had to do some measuring and double checking as I have a 2011 FXDB.
  • gordo68
    gordo68
    hi has anyone got the harley hard rigid saddlebags part number 91615-09A. I am thinking of getting some and would like feed back about them, eg do they leak are they strong or well made etc. Any input good or bad would be great also maybe some pics of the whole bag back front etc. Thanks
