Any ideas ??
  • Sooki
    Sooki
     I have a sissy bar fitted to my FXDF
    With the vibes of the bike wich I will say aren't that bad the fucken thing rattles like a bastard.
    Any one had this problem? Checked all the mounting etc all looks good. It doesn't quite fit snug as it should.
    Any ideas ?
  • Sooki
    Sooki
     Putting a passenger does fix it.
    I'm  thinking take it of when not in use but that's not ideal.
  • Sooki
    Sooki
     Sissy bar is removable and I did put tape on the bushes. It stopped the rattle for a while but it came back soon enough.
    Any way I will bitch to the dealer on first service. They might say that's normal but I will still bitch.
    Once the V & H go on the bike I won't here the rattle anyway.
  • Sooki
    Sooki
     Ok fixed the problem.
    I put an o ring on each rear bush then fitted sissy bar over the o rings.
    Problem fixed no more rattles.
  • Gilesie
    Gilesie
    putting the Ol lady on the back stops the rattles but then the nagging starts.
    Filthy, how much you be wanting for the brackets i might just be interested and are they black or chrome?
