Brake pad change - FatBob
  • FatRob
    FatRob
    Can anyone tell me what the sizes are of the 12(?) point headed bolts that hold the brake pads in on a 2011 Dyna?
    And does a normal socket it or do I need some costly HD special part?
    Thanks,
    FatRob
  • FatRob
    FatRob
    Do I need Torx sockets?
    Help on sizes would still be good...
  • BURTO
    BURTO
     Ordinary 10mm (12 point) socket mate.
    Burto.
    10mm 12 point ring spanner works, unless you use power tools.
  • FatRob
    FatRob
     Thanks to all who replied.
    10 mm ring did fit the front but the rear needed a 1/4 A/F (6 mm?).
    FatRob
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    if ya buying sockets for the mancave best to have a set of SINGLE HEX and DOUBLEHEX thats wat the tool places call em
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    try buyin a double or multi hex 1/4 inch socket for undoin evo lifter blocks most shops only got single hex but trade tools carrys most multihex
