badging denim black
  • Train
    Train
    Fellas,
    I've taken my badges off and most of the rubber behind with a hair dryer, but there is still a real fine layer of rubber stuck to the tank and i cant get it off. I know eucalyptus oil will do the job, but im not sure about using it with denim black.
    Anyone got any idea? Cheers
  • Daggs
    Daggs
    I used som citric acid stuff when I did my reflectors and it was fine on my rear guard, I have the denim black also
  • Train
    Train
    cheers daggs, ill look into it
  • Daggs
    Daggs
    No it's so easy, excellent to deal with
  • nhb006
    nhb006
    I had the same issue. i used prepsol, polish (yes, car polish) and windex.
    All gone. No bright spots, looks like new. - It like anything, dont go to hard and it will be gine.
    Off topic, Train, what popes did you replace your bassani with?
  • Train
    Train
    Macka, the denim bikes are easy . Just hit with Windex and she's clean.
    NHB, i put my old bassanis back on. Black 2 into 2 firesweeps
  • nhb006
    nhb006
    Ive been looking pretty srriouslt at those. I just find the road rage 2:1 quiet. Do u feel that you've lost any torque by swapping back to the 2:2's? You wouldnt be able to post up a side on pic of your bike with them on?
