Online: brucefxdl
Difference in brakes after wash?
  • kingchops
    kingchops
    18 years ago
    Washed my bike on Sunday, (first time in a while) and I used that HD tyre and wheel cleaner on my wheels.  I must have sprayed some of it on the brake disc or pads because this morning when I took the bike to work my brakes are noticeably different as in not as good.  My front brake especially seems to be slipping.  Have I stuffed by brake pads or will they come good after a few grinds?
  • kingchops
    kingchops
    18 years ago
    Scotty,
    Yes, I'll give that a go I'll take her out at lunch time.
  • kensim
    kensim
    18 years ago
    dont put shit on ur brakes,ts a no no,simple as that
  • kingchops
    kingchops
    18 years ago
    kensim,
    yes that's definately good advice after my experience. Brakes seem to have come good a bit after some hard braking at luch and on the way home. Hopefully they'll come good with a bit more grinding tomorrow.
