Online: speedzter
Iron 883
  • Fattybob
    Fattybob
     Looking at getting myself an 883 as a first Harley, any thoughts of advice?
  • Etch
    Etch
    Welcome Fattybob hope you enjoy the forums and on the bike i rekon it would be a great first Harley Depends how big you are some of the ridding postions on a sporty can be a bit cramped if you are a big bloke.
  • brad
    brad
    Welcome BOB u should get a fatbob
  • Fattybob
    Fattybob
    Thanks guys
    Welcome and get a Dyna
  • Fatman
    Fatman
    Go with the sporty...but try the 1200...they are a great bike. Good luck & welcome.
  • fattatt
    fattatt
    Welcome.
  • deesy
    deesy
  • Taffymarsden
    Taffymarsden
     Fatty bob, just read my signature for my opinion on the Iron. :)
    Daimoh on this forum has one for sale with about 8,000 on the clock and a lot of extras including pipes, breather, tuner, shocks etc. Goes like the clappers.
  • evileye
    evileye
    Welcome and good choice for starters, sportsters are a great ride. Agree about considering the 1200 over the 883 though.
  • Rxes
    Rxes
     G'day Fattybob, not much of an intro, do research on all rides that grabs ya and ride safe.
  • HWG
    HWG
    Welcome aboard matey.
  • black iron
    black iron
    I bought the missus an 883 iron that she never rides
    now 14.250 ride away .1200 sporties are about 3 grand dearer
    i bought a sreamin eagle 1200 stage one kit for $1650 and put it in with the help of a mate
    ive kept the 883 gearing so it gets off the line better than a stock 1200
    fairly simple kit to install  its just a bolt on
    deano
  • pan head
    pan head
    Buying a Harley was the best thing Ive done, go on do it... Welcome To the jungle
  • TC883
    TC883
     Welcome. Go the Iron, you won't regret it. Buy any other Harley and you won't regret that either! TC
  • black iron
    black iron
    Tc you should drop round mate for a beer and an iron comparo
    im in wollongong too
    wouldnt mind checkin out your side mount plate
    pm me
    deano
  • slapster
    slapster
    Welcome Fattybob, if yr on a budget mate then the Iron is a good starting point. You can upgrade from there as $$$ permit. Just make sure you do the stage 1 asap to open it up. A 1200/1250 conversion can then be done further down the track. For me I had the $$$ to get a 1200 but preferred the look of the Iron, found a 2nd hand 2010 for a good price & spent the spare $$$ on upgrades. Quick enough for now (I'm 90kg / 5'11") & the 1200/1250 won't be too far away.
    Slap.
