Online: Stuart
06 Dyna PCIII map
  • boofhead
    boofhead
    18 years ago
    My bike isn't running so well at the moment, so I want to start looking at the map that's on it before I take it for another expensive dyno tune. Even though I've had the PCIII on the bike for some time I haven't connected up and had a good look at it so Even if the rough running is not related to the map just out of curiosity.
    I thought I would compare the map on the bike with the closest I can get from Dynojet (wich is the same setup as mine but V&H big radius not Sideshots) or another reference map . Does anyone know of a site or have a good PCIII map that would match my setup closer (See sig) ?
    I do get a lot of popping etc. on decel so I wanted to up the zero throttle setting by 15 as suggested in another thread.
    Any other suggestions , ideas or comments ?
    Thanks in advance
    Boof
  • boofhead
    boofhead
    18 years ago
    I just loaded the Dynojet map for the same setup but with big radius. Comparing it to what was on the bike the new map is richer across the range. I'm still gonna up the zero throttle setting to address decel popping though.
    It's probably a better map than was on there but I've still got this annoying problem where after about 10 minutes of riding it starts missing and runnning badly.
    Guess I'll be heading to the mech next week.
    18 years ago
    hey boof... I have the 07 SB with kit listed in sig. I was running the big radious map (M814-003) as well but get popping as well. Did try another map that was emailed to me but as it was advance map I did not use.
    I played with the map a little then took it into local dealer and they set it back to 003 with only one chage and that was the 0 throttle and 500rmp. I still have a problem with warm/hot start too.
    Let me know how you get on. I am going to play around a little today.
  • boofhead
    boofhead
    18 years ago
    The V&H map for my bike has 7 for front and rear pots @ 500 and 750 rpm. One of the other guys here recommended 15 at all rev ranges. I thought I'd try 10 first and see how it goes.
    Boof
