Speedo/Tach
  • bear640
    bear640
    Hi guys,
    New member here,, first post. I own a 2011 fatbob & bought a HD speedo/tach  PN 70900071.
     I followed all the instructions on fitting it , took the bike for a 65km ride but the thing won't work. All the lights & LED parts work but shows up VIN ERR . Can anyone help? Did I miss something?  What am I doing wrong?
    Thanks in advance, Bear
  • bear640
    bear640
     Yea, done the transfer cable under the seat. Will give it another go next w/end & see if it works this time.
    I put the original speedo back in as it's too easy to be above the speed limits
    Thanks
  • Aussie XB12SS
    Aussie XB12SS
    Not trying to be a smart arse but I take it you mean under the side cover?
    It should only take a few seconds to do & have a message confirming that it's done. Can't think of what the message is.
  • bear640
    bear640
    I found my plug under the seat (same as your pic) & come to think of it i didnt see a message.
    Thanks for taking the time to take photos Aussie,, much appreciated.
  • bear640
    bear640
    Got it worked out,, thanks guys. Yes, there is a 2nd plug under the seat that I got mixed up with. The video shows how easy it is (with the right plug)
  • HWG
    HWG
    Glad to be of service...
  • chrisb
    chrisb
    Has anyone had any problems with these tacho/speedos? I had one installed about 6 months ago and a couple of weeks ago, things started to go wrong. The security light is staying on, sometimes the gear indicator disapears and now the left hand indicator stays on permanently which in turn partly melted the smoked lens. The dealer that installed it says that it may be a faulty sender in the unit. Until it is fixed I can't really ride the bike, because if I take the accessory fuse out I don't have a tail light. It's about a 1 hour ride to the dealers and I am a bit reluctant to take the risk.
  • Black1
    Black1
    Does anyone know if a fatbob instrument panel will fit a wide glide tank (2011) ?, I know they are different sized tanks.
    I purchased the same speedo/tacho on the 1st March 2012 from Peter Stevens Motorcycles after they told me it would fit my bike, it doesn't as the wide glide has a 4 inch speedo..
    Have been waiting 2 months for them to decide what they are going to do, refund/credit, return the speedo to me, do nothing and hope I forget about it ???
    They have the speedo and I have nothing other than a reduced bank balance, if the a fatbob instrument panel fits my tank I'll endeavour to get it back and see if I can source one from somewhere as I'd like a tacho.
    Any help would be appreciated.
  • Aussie XB12SS
    Aussie XB12SS
    I think you need to push a bit harder for a refund or replaecment for the correct speedo.
    I've never had any trouble with them if the wrong product has been supplied. Send Luke or Sam from HH a message price@peterstevens.com.au
  • flacky
    flacky
    I just fitted a Tacho/speedo to my '12 superglide custom and it's working great.
    Just be aware that the '12 dynas and the '11 softails on are different to the earlier ones.
    No need to calibrate anymore and the instructions say you have till the 50klm mark to remove the instument before the gauge takes on your previous milage permently and can not be used on another bike as "error" will be displayed in the panel.
    Bought mine from the usa while I was there .
    Looks great so far and really easy to fit
    Can you post a pic of it and your bike flacky.
  • flacky
    flacky
    Here you go sorry about the wait
  • flacky
    flacky
    1 more
    Looks the goods Flacky , does the trip meter work as original ?
  • flacky
    flacky
    Yes it does
  • neilfxd35
    neilfxd35
    Can somebody please tell me how to set the clock
  • pat
    pat
    Disconnect battery 1159
    Reconnect 1200
    Or get clock up and hold trip button in for a few secs
    Numbers start flashing 24 hr 12 hr
    Quick press changes ,long press is next
    The coluors are a bitch
  • Jethro
    Jethro
    Hey Fellas,
    I added the same speedo / taco a few weeks ago the issue I have is the digital fuel guage seems to be about a quarter of a tank out compared to the analogue guage on the tank? Anyone else find this and which one is the go? I go with the lowest at the moment haha but want to know if anyone else found this?
  • Aussie XB12SS
    Aussie XB12SS
    From memory mine was like that to start with but came good. Think after I ran a full tank full through it.
