95 sporty wont start
  • rick0
    rick0
    hi guys i have 95 1200 sporty went for a ride yesterday stoped @ mates went to start it again no gooooo.lol plenty of fuel no spark tested coil no spark to coil..  was thinkn  stator  .. any fuses that cut power to coil   thanks ..ricko
  • houli
    houli
    Buy a workshop manual, a multimeter,and a compression tester its time to start learning, you will be able to teach yourselfand save a fortune and when you get stuck you will be able to ask the correct questions.
    For now see if you have power going to the coil, if you have, swap coils with a known good one, if you had a manual and multimeter you could check the resistance on your coil to see if it was rooted.
    Sorry if i come across as a smart ass, but if you own a bike you should put in some effort to learn.
     older bike model,   these ign system's do not last for ever if the ign system is over 4 to 6 yrs old then it will be more then likely that ,    put a crane hi-4 single fire in her   there cheap these day's
  • rick0
    rick0
    turns over. tested the back of coil  with multi meter when i was crankin it next ill disconect the kill switch on the coil have to get a manual  cheers
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    in evos n evo sportys i fit the ultima dyna ignitions cheap as an never had any shit the cranes had a bad run an heap of returns few yrs back didnt they
    the ultimas easy as shit to wire got three wires to coil an one to voes an thasts it unless ya got tacho an thers one wire for that should only take a hour even if ya not done one before just remember where your adjustment was down in the nose cone also gets rid of the black module box so no more under seat or side cover ect with standard shit if ya dont got the bucks for new ignition give me a yell most prob got a coil an standard module here you can have to get ya by till ya get the better setup
  • rick0
    rick0
    hi sounds good ron where is your shop cheers mate
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    bout 20k from you lol
    yes years ogo  the crane H1-4  could fail . but these days are made better i found that if you use a domed points cover as so it 's not resting on the module box  & give & air gap  you will not have a come back,    i havn't  had 1 in 7 + yrs , the 1's that have failed can tell the cover gasket has the imprint of the module on it because  flat type points cover ,  it's been rubbing when you do up the cover screws ,   i'am not a fan of asian parts rev-teck etc  on american bike's  but if there cheap & work
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    ricko all sorted went away with few bits to play with and a complete mannual printed out for him all for a packet of smaokes an 2 ice coffees
  • rick0
    rick0
    yer a big thank you to ron what a nice bloke  knows his shit......
  • rick0
    rick0
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    fuck that cracked me up
    problem is wiring an ignition fucked but when ya on a budget any helps good had few spare as new ign bits in shed so rick wantin to try fix himself i give him the bits an printed out a manual for him
    atleast he can get on the road an have a go fixin himself till he saves for new wiringh an a new ign
    if ya got any more probs let me know rick im gotta go agnes waters in the next week or so
