FatBob indicator problem
  • FatRob
    FatRob
     My front left indicator has stopped working.  It isn't the lamp / globe / bulb as I swapped left for right and the right one still worked and the left one still didn't.
    Anyone had a similar experience and could suggest where to start looking for the problem?
    Cheers,
    FatRob.
  • Trendy
    Trendy
    Check the earth wire my left rear did the same last week......
  • Trendy
    Trendy
  • Trendy
    Trendy
    Damn it posted 3 times ? sorry......
  • FatRob
    FatRob
    Thanks Trendy.  I'll borrow a multi-meter and start prodding around.
    FatRob.
  • FatRob
    FatRob
     Turned out to be the connector under the tank.  I must have disturbed it whe I changed the headlight over a couple of weeks ago and then it finally rattlled loose while I was out on Sunday.  All good now.
    Appreciate your help Trendy.
    FatRob
