Latest mod with 24kt gold spray can
  • swbob
    swbob
     Just sprayed my air cleaner mesh and timing cover with 24kt gold spray can.
    Next mod RSD tracker brass grips and foot pegs.
    What do ya think ?
  • PUNJABI_DuDE
    PUNJABI_DuDE
    Looks sweet
  • Rocky2010
    Rocky2010
    I have the RSD Brass Grips, they look great and they are very well priced for what you getting. Grips are very comfortable.
    Would like a set of brass rear pegs they look great, but I don't ride two up as the partner has her own bike so took off the rear pegs because they look shit with the standard pegs
    Had a set of HD Tribal grips previously and they were crap, the ends of the tribal design started to rise like a curled up piece of paper, also they were expensive and the were looking tacky after 3months so I replaced them with the RSD Black Grips then the Brass Grips just like the look of the Brass grips better.
  • Rans
    Rans
    looks nice mate.
  • swbob
    swbob
     Thanks for the feedback,orderd the rsd parts today
