Online: HD17
Indicator Query??
  • wolvy29
    wolvy29
    Hi. Just bought my first harley, a 1985 softail. Just have a question about the indicators. Is it normal that I have to hold the button for the blinker to stay on? As soon as I let it out, it turns off. I come from sports bikes where you just click it and then push it in to turn it off. All I have is a button on each side but no way to turn them off!!
    Any help is greatly apperciated!
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    if ya press button once they should come on then press again should go off on the earlier ones some had a proper on off switch like the jappas too
  • wolvy29
    wolvy29
    any thoughts on what might be stopping this from happening?
  • Crowy
    Crowy
    thats standard on some
  • Bourkie
    Bourkie
    just imported an 85 FLHTCL had the same problem turns out some states in US u cant have a blinker that stays on so the made it so you  have to keep ya thumb on the fucker. I was told on here to put a badlands TURN SIGNAL CANCELLER , this I did and it worked fine got mine from http://www.eastcoastcustom.com.au  this is their blurb http://www.badlandsmotorcycleproducts.com/2008/Products/BETCSM.htm#ATSIII  I think it cost around $100 with post from ECC fitting is a breez just read the paperwork well just remember if all else fails read the directions
