Online: Hilly, FONTANA302
Freedom perf independence shorty exhaust, anyway of baffling?
  • Darren74
    Darren74
    Hi guys, Does anyone have any experience with the freedom performance independence shorty exhaust in relation to either quieting it down or using a quiet baffle out of another brand such as Vance and Hines? As Freedom don't do a quiet baffle.. I ask as I like the look of the exhaust (in chrome) on my Big blue pearl Iron, but it has a rather sharp crackle to the note that goes through my head while riding in the lower midrange such as around the burbs and town. It came with a form of removable baffle standard. Thanks for any help or recommendations!
  • Darren74
    Darren74
    Thanks, I'll have a proper look at thunder city baffles when I get home. I'll have to pull out and measure the current "baffles" and pipe diameter.
  • Black Mamba
    Black Mamba
    when I emailed BUB bout the same question for my pipes, they said stick some insulation in there, like pink bats! don't think i'll try that one.
  • Bunyip
    Bunyip
    Where do you live
  • Darren74
    Darren74
    I got some thin muffler fibreglass mating and tried to wrap the standard baffles, but there wasn't enough room left to put them back in. I even tried to wrap the fibreglass in tie wire, but still no go..
    I live in Brisbane.
  • calais
    calais
    Take the standard baffles to any decent exhaust place and ask them to tack a perforated cone over the leading edge of the baffle.This cone coupled with the fibreglass baffle mat from a Dirtbike store should really kill the crackle.
  • Bartikus
    Bartikus
    I took my iron to Motorcycle Exhaust Professionals just off of Moss st in Slacks Ck, they put the exhaust fibreglass around my baffles in my V&H short shots, sounds heaps better, and gave it a bit more punch off the mark, only cost around a hundred bucks,
  • calais
    calais
    The wrap itself can be purchased for less than $20 if your keen to do it yourself.
  • als1200
    als1200
    Does the perforated cone on the front give it a bit more back pressure?
  • als1200
    als1200
    Just finished putting the matting over my baffle. Tight but the matting purchased could be split apart to halve the thickness. Fired her up in the shed and I can pick a difference. What does the perforated cone do, just quieten it down more? I have a set of quiet baffles as well and might get them modified as calisis mentioned. I have v&h hs. Thanks for the ideas.
